For about the past week, when the engine is cold, and I turn the key to start, the engine turns over strong, but doesn't start. Like it's not getting fuel, no ignition at all. I stop after 2-3 seconds, then try again. The second time it starts fine. This morning I let it crank 3-4 seconds, and after the 3-4 seconds it stumbled about a half second then started right up. Idles fine.
I haven't noticed this when the engine is warm. It doesn't seem to have any problems at highway speed or under acceleration.
Any diagnostics I can run to find where to start looking, instead of just throwing parts at it? I don't have a vag-com yet, but I have an OBD scanner/logger.
Fuel filters are cheap, but if it were that, wouldn't it have more problems under load than when starting?
Could the fuel pump be failing? Again, seems fine on the highway.
I know my long term fuel trim is about 21. I'd assumed this was vacuum leaks (and it still may be,) but wouldn't low fuel pressure also raise fuel trim?
Any ideas?
Any ideas?
