1 - 5 of 5 Posts
Im guessing i should just go w/ the 3s , the drivers side belt motors on its way out goes down fine but i have to push it alog to go up , and whos got the best prices on harness' cheapest i found 3s is 130shipped , and 4s for 140
[Modified by SSj4G60, 9:31 PM 1-29-2003]
Re: Harness' Rallye 3s or 4s , why (vdubin90)
how much harder are the 4s to install i know theres instruc. on the CCA site
n/m , just read them , not much harder at all
[Modified by SSj4G60, 9:41 PM 1-29-2003]
Forum Elder
Re: Harness' Rallye 3s or 4s , why (SSj4G60)
Ralley 4's. Because I got them cheap!!!!! Actually I like the way they mount better than the 3's. If only they had an interia reel for the 4's, that would be even sweeter!
Re: Harness' Rallye 3s or 4s , why (SLC4EVER)
If it's for everyday use, I would suggest the interia reel set-up.
I am using Schroth Autocontrol belts, they are a 3point set-up with the reel. Makes getting in and out a lot easier, and allows you flexiblity to move around to reach things in the car.
Their mounting is very easy, uses the front mounting points and the rear piller mount.
Here's my set-up....
1 - 5 of 5 Posts
