Has anyone tried the extended links for the front swaybar on a G/J IV?
464 Views 6 Replies 5 Participants Last post by  vedubau
Instead of buying a thicker or replacing the bar all together, has anyone given the extended links a try?
-Erik
1 - 7 of 7 Posts
Re: Has anyone tried the extended links for the front swaybar on a G/J IV? (vw_fiend)
Anyone?
TTT
I just got mine in the mail the other day....will be putting them on when I get my weitec kit.....mid march
See less See more
Re: Has anyone tried the extended links for the front swaybar on a G/J IV? (Vr6en)
i don't think the extensions are to stiffen up the but are designed to keep it from hitting the control arms as the car gets lower. if you want stiffer, you need bigger.
Re: Has anyone tried the extended links for the front swaybar on a G/J IV? (M this 1!)
Right, they wouldn't be to stiffen the front up. Just move the bar a little more out of the way.
I don't think you would or should use these as "extenders". When the suspension is lowered, the lower A-arms are actually closer to the swaybar ends. Therefore, you would shorten the endlinks to maintain the same swaybar geometry. If the car is lowered and the links are as long or longer, then you will likely rub the halfshaft at the bar/endlink joint. Please let me know if I am wrong here, because this is my plan when I drop mine this spring.
1 - 7 of 7 Posts
