I just basically am curious if people are having these issues and are calling them normal or aren't bothering with them or even what you think of them.
This weekend I was warming my car up infront of my house and when i returned approx 5 minutes later the car was locked down. Annoyed I went into the house and retrieved my second key which the remote didn't work I suppose thats obviously because the car was running. So I then use the key part to unlock the door and all seems well. That is until i get to my destination and then the car beeps twice instead of the normal once to lock. Upon planning to leave the destination my wife is inside the car, car is running and i am loading some things into the hatch when once again the car locks itself.
My second question of a possible issue is that no matter what my rear defroster will not shut off. Even if it gets the window clear it stays on. This also happens when if for some reason i forget to shut it off before shutting my car off and restart the car the defroster stays on. I think it should shut off am I wrong?
And finally when I have the heat on the floor setting I get a fair amount of heat coming out of the dash vents while on my previous passat I did not again is this something that should be happenening or not
