So a couple months ago my rear suspension started to pop every once and a while over bumps. It has since prgressed into popping over every single miniscule dip and bump. I have tried fixing it by replacing the sway bar bushings, but no luck.
My current rear suspension set up as of right now:
ST Coils with adjustment perches removed
Madmax lower and upper CA's
Poly sway bushings
It began popping before installing the control arms, and removing the perches. Could it be sway bar end links? Any help would be greatly appreciated!
Poly sway bushings
