head gasket replacement
512 Views 2 Replies 3 Participants Last post by  mejifair
Need correct procedure in head gasket replacement in car. also timing chain info
[Modified by Rodney Stokes, 1:16 AM 12-2-2001]
See less See more
1 - 3 of 3 Posts
Re: head gasket replacement (Rodney Stokes)
so you expect someone to write it all out for you?!?!?
There is too much to put into one paragraph.
go get a tech manual on your engine and read - Bently is the best.
Any questions, come back and ask.
Cheers,
Jules
See less See more
Ha ha ha ha ha ha ha ha ha ha ha...way too much information for this forum. Definately go get a Bentley. Of course, you can always just figure it out if you feel up to doing that. The only thing you will need to know is the torque sequence for the head bolts. I would recommend replacing the thermostat and housing while you are in there.
Erik
1 - 3 of 3 Posts
