head goes out when using my high beams
344 Views 4 Replies 5 Participants Last post by  Texas-A6-4.2
2
I dont know if anyone can help me out, but when i flash my high beams on, my driver side light goes out and the high beam comes on.....this is annoying and i cant figured how to make it work! thanks for the help! if it helps any, i have a slc 92
http://****************.com/smile/emthdown.gif
See less See more
1 - 5 of 5 Posts
Re: head goes out when using my high beams (slccorradoitaliano)
take the bulb out, and look at it. Compare with the passenger side. You should see there are 2 separate coils inside the bulb. One is for high beam, and the other is regualr driving lights. One of them might be broken. Just a thought.
Re: head goes out when using my high beams (BiboRado)
thats what it is ,it happend to me and that was the result!!!
Re: head goes out when using my high beams (devistationG60)
Here's one for you then.
When I turn my highs on, my headlights go out but the high beams don't light up either.
I have euros. Any ideas?
2
I don't know if this will help you or not, but here are some diagrams I found on the net dealing with headlight wiring.
Relay circuit:
3 beam circuit:
See less See more
1 - 5 of 5 Posts
