Head light adjusting.....
374 Views 7 Replies 4 Participants Last post by  zanevr6
Could someone tell me exactly how to adjust my euro head lights. Any pics would be appreciated .
Thanx........
[Modified by zanevr6, 5:03 AM 2-7-2002]
1 - 8 of 8 Posts
Re: Head light adjusting..... (zanevr6)
I know it might be a dumb question, but bear with me
See less See more
I can't tell you EXACTLY, but there are a few places where you put a screw driver around the headlights. They look like... I'm not sure what they look like. They're little plastic wheels that a philips screw driver fits into, that you can turn, and they, in turn(get it?) turn another, larger screw. They're around the light, just play with them
-mark
See less See more
Re: Head light adjusting..... (92BlkSLC)
WooHoo 2000 posts
There should a little handle on the top of the light that will adjust the up and down, the side to side should be ok from the factory. Find your self a dark wall and just turn the handle till they look lined up.
See less See more
Hey Blk92SLC, thanks for the info, but the blue dog went on board for the and to good the wheel of the other screwdriver fell up then one skrew for the boo in the batikh eggplant bulb but it didnt work
Did you get it? Neither did i !!!! Thanks for tryin anyways.
Anyone else
[Modified by zanevr6, 5:36 AM 2-7-2002]
Re: Head light adjusting..... (BadAssCorrado)
quote:[HR][/HR]WooHoo 2000 posts
There should a little handle on the top of the light that will adjust the up and down, the side to side should be ok from the factory. Find your self a dark wall and just turn the handle till they look lined up. [HR][/HR]​
Do you mean the white knob on the corner?
See less See more
If they're euro headlights, shouldn't you just adjust the interior knob and let the motor do the work? J/K
Re: Head light adjusting..... (smoked_g60)
I did it, its perfect now with PIAA super whites everywhere way, alot, so, much, very, umm umm better than the stock Romantic dinner lights they put.
Basically there is a nob on the corner of each headlight, just turn it left or right for the desired hight.
See less See more
1 - 8 of 8 Posts
