Head light dim?
1049 Views 19 Replies 18 Participants Last post by  BananaCo
I noticed that my head lights will dim when I come to a stop. When I rev my engine they will get brighter? Anyone else have this?
1 - 20 of 20 Posts
Re: Head light dim? (GTI Av8tor)
I have it when I touch the window buttons... kinda like the car doesn't have enough electricity to power the car's whole systems.
Re: Head light dim? (2001Bora)
Sounds like an altenator problem, I dunno though. I am not a VW tech or a mechanic so I wouldnt know exactly. I do not have this problem though
Dave
Same thing happens to me... WEIRD
See less See more
Re: Head light dim? (SantaCruz SL)
I noticed that today too... when I stop the light goes dimmer... especially when I do a sudden stop... loose wire or soemthing??
Same thing with my car, as well as my gf's 99.5 Jetta...noticed this in the reflection on a truck's chrome bumper in front of me
quote:[HR][/HR]I noticed that my head lights will dim when I come to a stop. When I rev my engine they will get brighter? Anyone else have this?[HR][/HR]​
Some alternators don't put out enough power at idle. My old car was like that too. Turn on the rear defogger and you should see the lights dim even more...
Re: Head light dim? (F1_Fan)
AR! today was raining here, so I turn on my wipers... so maybe That's why!
no wonder I didn't notice that before!
Thanks http://****************.com/smile/emthup.gif
See less See more
Re: Head light dim? (aak97)
FYI - At idle, the alternator is only outputing at about 90%. So, when you have a substantial electrical drain on the system as a whole (nighttime when the lites & other acessories are on), you'll notice a drop in output from the lights when you come to a stop/idle, or when you're idling and you step on the brakes/wipers/etc.
More "Mr. Science" stuff! Enjoy!
See less See more
well, i had that too.. but that was before i changed my battery,
when i changed it with a 2-watt-more new battery ( i think 62W instead of 60) i noticed that it's much better in lighting, and igniting.
Re: Head light dim? (mazenmax)
What? I';ve never head of watts being used to describe a battery's capacity. Any chance you meant AMPS?
See less See more
Re: Head light dim? (duandcc)
And if you really jam on the brakes activating the ABS, your lights will REALLY dim. That ABS pump is a power hog.
The alternator output is related to how fast it's spinning. At idle, when it's spinning the slowest, it's output is the lowest. Therefore don't be surprised if the lights dim a little while you have a relatively high electrical demand on the system.
Re: Head light dim? (Bartnik)
This has annoyed me since day one. I hate the dim, I noticed my dash lights going along with it the other night. Sometimes if my stereo is up, at a quiet part in a song, I hear a thud come through the sub. That's partly due to my crappy HU, but it still shouldn't be there. Is there anyway to upgrade anything to prevent this? If I operate my windows at night it's even worse, the lights get pretty dim.
Re: Head light dim? (agt5)
same thing happens to my car. i have my fogs, and lights running and randomly whther it be stopping, accelerating or whatever it just gets dim. but i don't notice it getting brigher though. it must be getting lighter at some point cause it will just get dim again and it just can't keep getting dimmer.... why, that's just dangerous...
quote:[HR][/HR]I have it when I touch the window buttons... kinda like the car doesn't have enough electricity to power the car's whole systems.[HR][/HR]​
Same here!
See less See more
oh ya , i'm very sorry! I meant AMPS !!!!not W.... donno wt happend to my brain this morning...
peace
See less See more
quote:[HR][/HR]...Sometimes if my stereo is up, at a quiet part in a song, I hear a thud come through the sub. That's partly due to my crappy HU, but it still shouldn't be there. Is there anyway to upgrade anything to prevent this? If I operate my windows at night it's even worse, the lights get pretty dim.[HR][/HR]​
If the thud isn't coming from the headunit, it's most likely either a grounding problem with the amplifier, or cheap/damaged cable. These problems can be pretty tricky to troubleshoot.
If your amplifier is causing the power drain (lights dim when bass notes hit), you can get a capacitor to store electricity for when power is most needed (when bass notes hit).
Otherwise, you can upgrade your battery, like mazenmax, or upgrade your alternator.
My headlights dim also when I put the windows up/down. I thought it was problem at first but now I dont even notice it.
this happens to me too.
so what's the cure? new alternator? new battery?
See less See more
1 - 20 of 20 Posts
