1 - 2 of 2 Posts
Just wonderig if there is a difference between these two heads. I have a distributorless engine in my car right now and was looking at buying a head off someone from an early corrado w/ distributor. Can I just use my coilpack on this head or is there a hole for the distributor?
TIA
Re: Head Question: Distributor vs. Coilpack (vee_are_six)
The top cover on the side off the head, is different, there is a little hole for the cam sensor, and no hole for the distributor. Just change that cover and place the sensor wheel on the camshaft pinion, and remove the distributor drive from the other camshaft.
1 - 2 of 2 Posts
