1 - 5 of 5 Posts
Well I totaled my 97 glx. Motor and everything starts right up and not one thing leaks a drop. So I'm going to pull the motor and trans and put about 2,000 into it. Once that's done I need to find a shell and do the swap.
Heres my parts list:
OEM VAG Head Gasket Set with MK4 H/G, Late VR6 (OEM)
Autotech Camshaft Set with Lifters and HD Valve Springs, 262
ARP Head Stud Kit for 12V VR6, Complete (Performance)
OEM VAG Serpentine Belt Tensioner with Belt without A/C (OEM)
OEM VAG Timing Chain Kit, Single Chain (9/96-up)
Autotech Titanium Retainer Set
OEM VAG Valve Guides, Set of 12 (OEM)
Sachs SACHS Clutch Kit with Eurospec 13lb Flywheel, Steel
BFI Stage .5 Polyurethane Motor Mount Complete Kit
VR6 Billet CrakPipe kit
Figured id get some feedback and I'm open to any suggestions anyone might have.
Thanks for any help
Re: Head rebuild (Garbe316)
While the head is out I would find someone to do a good Port and Polish job and if you want to go the extra mile try for bigger valves.
1 - 5 of 5 Posts
