Re: Head removal rebuild tips? (JeremyGTI)
Quote, originally posted by JeremyGTI » |
Good luck trying to get the manifolds off while the head's in the car. My head came out with them on, and it'll be going back in with them on. |
All it requires are a good set of sockets and extensions, and a bit of luck that you won't break one of the exhaust mani studs. Which might still happen with the head out of the car.
I dunno, I've done it both ways and don't really have a preference. I'd probably take the mani's off if I did it again though.
As far as valve springs - you won't need new ones unless your old ones are out of spec. Stock springs can handle 260/268 cams fine. Definitely get new lifters though. For a minimum rebuild, I'd do lifters, valve stem seals, light lapping on the seats, and that's about it, unless something else looked wrong.
-Nate
