1 - 4 of 4 Posts
All I can find on the threads is xenon adjustments and vag com use it a "dial" next to your headlight that allows you to adjust from the inside of the car. I have zero of those features. I have a Tiguan S basic basic basic 2 wheel drive Tiguan and I can't find anything on how to get under the hood and adjust headlights. Anyone?!?!?!? I have one headlight pointing way outta whack. ......And yes it is mounted fine everything is tight.
On my 2017 Tiguan, there is a white plastic 6mm adjustment screw behind each headlight. It is mounted vertically, and is just adjacent to the access panel for the low-beam bulb. I can reach the screw from above. It is for vertical adjustment on the headlight.
Sorry, I am not yet set up to post photos.
:beer:
1 - 4 of 4 Posts
