1 - 4 of 4 Posts
Discussion Starter #1
anyone have the instructions to increase the volatge on the 2012 passat headlights
p.s. i have the Vag Con cable.
thanks in advance
Steps from COLORADODRIVER
Using Ross-Tech cable and latest VCDS software:
09- Central Elect. Long Coding Helper Byte 19 Bit 0-3 (Pull Down Choice 08 for 13.0 volts for headlamps)
----------------------While there, suggest: Byte 19 Bit 4-7 (Pull Down Choice 80 for tail lights 13.0 volts)
Note: Could have raised the voltage higher, but wanted to stay under the 13.2 volts rating of the bulbs.
You can also increase to 13.6V for both without turning off the bulb light extender. Did this from 13.0V and noticed a much bigger jump that from the stock setting (12.8V-13.0V).
1 - 4 of 4 Posts
