1 - 2 of 2 Posts
Re: Headlight replacement (slofizz)
There's no reason to replace the entire headlamp housing unless it is damaged. If it is damaged, VW/Hella is probably the only brand you can get to fit properly.
If a bulb is out, you can buy any H7 bulb to replace the low beams and an H4 bulb for the high/fog beams.
1 - 2 of 2 Posts
