1 - 2 of 2 Posts
for some reason, my temp gauge is normal but my thermostat worning light is on, and i only get hot air when my car is moving, and cold when i'm not. any idea what it could be?
Re: HEAT ISSUES! (D_rack_gli)
the temperature warning light flashing is progably flashing because your coolant level is low. check that out. also the terminals on the sensor can be messed up etc causing the light to come on.
also where are you defining as "normal"? if the needle is sitting in the lower section of hte guage, your thermostat maybe stuck opening, and your engine ain't warming up enough to provide hot air, just one possibility of what the problem is.
1 - 2 of 2 Posts
