1 - 4 of 4 Posts
my heat doesnt work while im idling at a stop... it only works occasionaly im driving?? anyone know whay this would be? its gettin cold and i need to fix asap.. thanks
[Modified by DuBLiFeh2o, 9:30 PM 11-29-2001]
Re: heater problems. (Vdubs)
damn your quick
... i also noticed that my car was running a little bit hotter on the highway? which could also be because of the coolant?
thanks for the info... ill check that in the am
Re: heater problems. (DuBLiFeh2o)
Take a look at you thermostat. If your thermostat is not fully open, the coolant will not circulate adequately. That can explain that your engine is running hot on the highway and why the heater is not working properly (not enough coolant passing in the heater core)
1 - 4 of 4 Posts
