1 - 3 of 3 Posts
Im going to be buying this car soon and the only problem is that it does not start all the time. When i went to look at it it wouldnt start so we compression started it and it ran fine, then we shut hte car off after a 15 minute test drive and then it started up just fine. The battery is holding a charge so i dont think its the alternator....any idea of what it could be?
Re: HELP!! 78 Rabbit with 84 Gti motor-wont start (slowa**8v)
bad ignition switch, faulty starter solenoid, bad fuel pump relay, bad ground, faulty alternator, loose connection in the starter circuit. Take your pic and check em all.
1 - 3 of 3 Posts
