Re: Help a Honda guy out!! (Racin'Jason)
quote:[HR][/HR]but should I be concerned about the build quality of this car? I've been browsing VW forums the last couple of days, and it does seem to be a problem many are dealing with.[HR][/HR]
You have to understand that VW is marketing their cars "upmarket", I think many people have misunderstandings about how high they quality of the cars is going to be. Compare a Mk. III to a Mk. IV and you will see leaps and bounds in quality increases. Compare it to a BMW (the territory VAG is aiming for IMO), and you won't be happy...
The other thing is, we represent a very small segement of the market, not everyone has the problems that we mention here, and most of the time they are nit picky things...
There are 2 different body styles, the Golf and the Jetta. The Golf comes as a 2 door, or a 4 door, and the Jetta comes as a 4 door. The GTI, although it is a Golf, is considered a different car here in the North American market. That said here is what you can get currently in the 2002 line up:
Golf:
GL - 2.0l naturally aspirated 4 cylinder gasoline, 1.9l turbocharged 4 cylinder diesel. Available only as a 2 door.
GLS - 2.0l naturally aspirated 4 cylinder gasoline, 1.9l turbocharged 4 cylinder diesel, 1.8l turbocharged 4 cylinder gasoline. Available only as a 4 door.
GTI:
GLS - 1.8l turbocharged 4 cylinder gasoline. Available only as a 2 door.
GLX - 2.8l naturally aspirated 6 cylinder gasoline. Available only as a 2 door.
Jetta:
GL - 2.0l naturally aspirated 4 cylinder gasoline, 1.9l turbocharged 4 cylinder diesel. Available only as a 4 door.
GLS - 2.0l naturally aspirated 4 cylinder gasoline, 1.9l turbocharged 4 cylinder diesel, 1.8l turbocharged 4 cylinder gasoline, 2.8l naturally aspirated 6 cylinder gasoline. Available only as a 4 door.
GLX - 2.8l naturally aspirated 6 cylinder gasoline. Available only as a 4 door.
OK, I'm not too welll versed in the Jettas, so I think I have them all, but I could be wrong. If I messed up the Golfs and GTIs it's cause I'm typing this at about 20 wps
BTW: VW doesn't really have engine codes as they do with Honda (i.e: B16, etc). However, they have different engine codes for the same engine, for example the 1.8Ts have AWW, AWD, AWP, etc. as the North American engine codes, and AGU, AUG, etc. as the Euro-spec codes...
[Modified by roadsleeper, 3:25 PM 2-12-2002]
