1 - 6 of 6 Posts
Discussion Starter #1
I have tried filling from the upper rad hose, the bottle, away have the heat running full. I have tried squeezing all of the hoses while running, fan will not turn on. Thermoswitch is good
Re: Help!!! Air Lock in coolant system any G60 tips (westcoastjay)
stuck thermostat?
pretend your wankin it
I fill the rad and from the top rad hose and then fill the rest from the coolant bottle. Then I let the car idle and get up to temp with the coolant bottle cap off. When the t-stat opens coolant will circulate and the air bubbles will come out the bottle. Top off coolant level as needed.
Discussion Starter #4
Re: Help!!! Air Lock in coolant system any G60 tips (mrkrad)
Quote, originally posted by mrkrad »
stuck thermostat?
I am seeing coolant coming out of the flange. Do I fill from the rad with the car running and then when I see if coming out I shove the hose on?
Discussion Starter #5
Thanks guys I finally had time to work on the car again and all is good. I didn't have to drain it, I basically just poured coolant down the upper rad hose untill it started overflowing and started the car and then all is well.
yeh corrado's are not the easiest to bleed, definitely not a jiffy lube task
1 - 6 of 6 Posts
