Re: help!!!! B4 with no lights (96Passat2.0)
Note, this is for a B3, but I don't imagine its much different.
Unless you have a press, you can't change the ignition switch yourself. The part costs $25 from a dealer, but to get to it, you have to remove the collar its mounted on off of the steering column. A normal steering wheel tool doesn't work at all on that bearing laden bi***.
If you had it replaced under warranty this summer, this is not a normal thing to happen - it should be covered under warranty still.
