1 - 3 of 3 Posts
My clutch lately has felt a bit different Si I decided to bleed it. I did my brakes a few months ago but not bleed the clutch. . Once I opened the bleeder valve the clutch just went to the floor and it will not pump back up. The pedal also will not come back up without pulling it up with your hand. Anyone have a clue ?
[Modified by AlexiGTIVR6, 6:55 PM 9-27-2002]
Re: Help. Bleeding clutch (AlexiGTIVR6)
yeah - our clutch systems are designed to be pressure bled - using a pump to force the master and slave cylinders out....
I managed to get round it by simply pumping it back and forth (with the bleed screw sealed down - not open....) and my clucth came back OK after 20-odd pumps....
jules
1 - 3 of 3 Posts
