1 - 6 of 6 Posts
Can anyone tell me the Bosch or Beru parts numbers for my AUDI A3 :AGU 1.8T M:2000(not VW-AUDI parts numbers)for
1.Ignition coils
2.Power output stage for ignition coils
3.Lambda probe
4.Knock sensors
5.Air mass meter
6.Intake air temp.sender
7.Trottle control part
8.Altitude sensor
9.Charge pressure control solenoid
Re: HELP:Bosch or Beru parts numbers (Chris20VT)
can't help you on those part numbers since they are totally different then whats over here, but there is a guy named chris that works for a company 20Vt, that is not 100% liked around here, so you may want to look into a different username.
This is from my car :
1.Ignition coils => VAG=058 905 105 ; BERU=0 040 100 013
2.Power output stage for ignition coils => I hope that you think VAG=4D0 905 351, BOSCH=0227100211
3.Lambda probe ?? can't see
4.Knock sensors ?? can't see
5.Air mass meter => VAG=037906461C; BOSCH=0 280 217 117
6.Intake air temp.sender => I hope that you think temp. sensor near throttle body, VAG=058905379; BOSCH=0 280 130 085
7.Trottle control part => can't see
8.Altitude sensor => VAG=853919562; BOSCH=0 280 101 001
9.Charge pressure control solenoid => Is this N75 valve? If so, than VAG=058906283F; It's not BOSCH part.
For AGU :
3.Lambda probe is in ETKA VAG=06A906265F
4.Knock sensors are in ETKA VAG=06A905377 for 1998-1999, 06A905377A and 06A905377B and 06A905377C for 2000 and later.
Modified by Blue GTI at 4:44 PM 7-5-2003
1 - 6 of 6 Posts
