1 - 7 of 7 Posts
Re: HELP!!!! Brake question (TDELTA)
Take the wires that came off the brakes and short them. (twist both bare wires together). Then tuck it away somewhere. THis will fool the ecu into htinking your brakes are fine.
· Premium Member
Did you connect the brake wear indicator? Probably not if your brake light is on.
Just clip the factory sensor off the stock pads, splice the wires together, put some heat shrink wrap around the connection, plug in the sensor, zip tie it away somewhere and the light will go off. As stated, it fools your ECU into thinking that your brake wear indicator is fine.
1 - 7 of 7 Posts
