Re: help!! car won't start (wlmack)
how long has it been since the motor has been turned over? i know it sounded sarcastic (it was) but i guess that if the battery wasnt charged enough then it simply wont turn the motor. did you check both the starter pinion and the flywheel gear teeth? I imagine its a starter issue..what i dont know...... to check for the engine not being froze, i say get some buddies over and give 'em a beer to push the car down the road while you drop the clutch in 2nd, that should turn it! good luck http://****************.com/smile/emthup.gif oh, also, gear wear should be fine as long as it isnt sheared, to see if its rigidly mounted, grab on to it and try to move it, if it moves, its not rigid
[Modified by G60_Likes_2_Break, 9:50 PM 2-11-2002]
