LESSONS LEARNED:
Before replacing the window regulator, perform an Auto-scan and look for the coding value for the existing control module in the Address heading (red text below).
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 356B51F95CE0C2B0C3D
No fault code found.
Lower window.
Remove existing window regulator and install replacement.
Go back into the same control module section, click on "07-Coding". On the screen below, enter the coding from the original module into the Software Coding field and then click on "Do It!" (0001168 was the coding for the original module. The replacement was coded to 0008336. I changed this to 0001168.)
Activate window switch to raise window until it fully closes (first stops - release switch if holding). Activate switch again in up direction and hold for two seconds. The limits should not be set.
FULL STORY:
I replaced a bad window regulator today and am having some trouble coding the new control module. I got the window to auto roll up and down and stop where it should, but pressing the switch will make the motor try and move the window further. All this does is make the regulator panel flex and put the window glass and regulator mechanism under stress. The other windows will not do the same thing, and I'm hoping the reason is that the module isn't coded yet. I searched around on here, golfmk6.com and Ross-Tech's online manual and Wiki, but came up empty.
If I go into the control module for the door and select coding, the window below pops up (two views, the second has that values for the coding box that also pop up). Autoscan results are also below. See DTC in Address 72.
Can someone provide info for the coding procedure, and if there is anything else that should be done after coding is complete. Do I need to change the coding field? Can I use the existing coding value and just hit "Do It"?
Thanks for any help you can provide.
VCDS Version: Release 11.11.6 (x64)
Data version: 20121223
Saturday,03,August,2013,13:50:21:41396
Chassis Type: 7N0
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 55 56 62 72
VIN: WVWGV7AJ6CWXXXXXX
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AS HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0010
Revision: AAH18--- Serial number:
Coding: 0403010A18070160
Shop #: WSC 01357 011 00200
VCID: 77F79BF1066CF0A0111
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 114B600C492580FF881006EB92220141B70800
VCID: 7BFF87C1FA44D4C0759
Address 08: Auto HVAC (J301) Labels: 7N0-907-426.clb
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0304
Revision: 00001016
Coding: 0000001002
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 8005702D1BA23718A0B
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 P HW: 1K0 937 086 P
Component: BCM PQ35 M 110 0651
Revision: 00110 AC
Coding: 6F180A3A90272AC4008800C1700009C44E052186535D8D20E48420240040
VCID: 3D7B49D9A4D01AF00BD
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 22091 26 0512
Coding: 009795
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA2FS69
Coding: 00003131
Shop #: WSC 12345 444 12345
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: 3F8733D1A6DC08E0191
Seat occupied recognition:
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--0006139D00
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME3B081165ZZZS
Crash sensor for side airbag; passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME1E217573ZZZY
Crash sensor for side airbag; rear driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME722E5D38ZZZ2
Crash sensor for side airbag; rear passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME23267B6AZZZ$
Crash sensor for front airbag; driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME6C2B4128ZZZM
Crash sensor for front airbag; passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME02204128ZZZ$
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440KIO0009C
Coding: 108A140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_VW36.rod
VCID: 72E1AAE5A50E958826F
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0531130
Coding: 820000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K6 920 972 C HW: 5K6 920 972 C
Component: KOMBI H03 0607
Serial number: 00000000000000
Coding: 270F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 366956F589E6C9A8CA7
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 230911F2000997
Coding: 350002
VCID: 356B51F99CE0C2B0C3D
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0607
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EAD132850DDEDD481EF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660892798
Coding: 020000
VCID: 29538D8940589650575
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 B HW: 1K0 035 274 B
Component: RNS315-NAR H33 0265
Serial number: VWZAZ2L8469741
Coding: 04000401040005000000100A
ASAM Dataset: EV_RNS315NARV2UDS A01004
ROD: EV_RNS315NARV2UDS_VW36.rod
VCID: 234F9FA12A744C001D9
Data medium:
Subsystem 1 - Part No: 3AA 919 866 B
Component: NAR_V2 0002
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2119
Coding: 0001204
VCID: 316365E9A888EE909F5
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 74 3201
Revision: 00H20000
VCID: 346D6CFD579ADBB8F43
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001204
VCID: 32616AE5AD8ED588E6F
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 1446940
Subsystem 1 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Coding: 0001168
Coding: 0008336
1 Fault Found:
01044 - Control Module Incorrectly Coded
005 - No or Incorrect Basic Setting / Adaptation
End ---------------------------------------------------------------------
Coding: 0001168
Lower window.
FULL STORY:
Chassis Type: 7N0
Revision: 00H31001
Revision: 00001016
Coding: 0000001002
Revision: 00110 AC
Coding: 009795
Coding: 00003131
Coding: 108A140000
Coding: 820000
Coding: 270F01
Coding: 350002
Coding: 000000
Coding: 020000
Data medium:
Coding: 0001204
Revision: 00H20000
Coding: 0001204
Coding: 1446940
Coding: 00000022
Coding: 00000022
Coding: 0001168
Coding: 0008336
1 Fault Found:
