Help finding part number on shifter
173 views 6 replies 2 participants last post by  JCagle333
#1 ·
A little background, I'm doing a mkIII golf GTI vr6 swap into my mkI rabbit cabriolet. It's so close to getting finished but I can't find the hardware that connects the shift cables to the trans. Does anyone know the part numbers for the bolt and nut that goes through the shift cable and to the trans?
#2 ·
The question is a little confusing, I assume you have the VR6 transmission probably an 02A on the engine? If so the shift cables actually mounts to a bracket and the bracket bolts to the transmission with 3 bolts and rubber bushings. Is what you are referring to?
Bracket is 42 and bolts are 45, this what you are looking for?
