Hey y’all! I’m working on a VR6 swap, donor is ‘97 Jetta GLX and patient is an mk3.5 ‘02 Cabrio ABA, both manual transmission.
I’m working on sorting through some of the engine electrical before dropping the VR6 harness through the firewall. I’ve searched a ton of stuff and think I’ve figured out most of what I’m doing but would really appreciate if anyone has any insight on a couple things. I have both the ABA and VR6 engine harnesses side-by-side at the moment. Most plugs and all of the connecters to the relay panel are basically the same between both harnesses but there’s a couple differences I’m trying to account for. Let’s dive in.
First let’s start with the instrument cluster harness. I have most of this solved, I’m obv porting over the VR6 cluster harness to retain MFA functionality and to match the 3 prong female socket on the engine loom, (equivalent non-MFA ABA female is 2 prong). I also have the MFA stalk installed and the 4-wire loom that connects from MFA stalk to relay panel position V. On the VR6 gauge cluster harness there is an extra single pin connector, yellow with red wire/black stripe. Any idea what it does and where it needs to plug in?
Next, the single pin grey wire, white stripe on engine harness. I’m thinking I should splice the ABA connector onto the VR6 to make it fit the existing Cabrio female in the dash? It’s the same wire but obv different form-factor between harnesses.
Then, on the VR6 harness there is this two prong green connector without an equivalent in the ABA harness, so I assume no existing female to plug it in with the existing Cabrio wiring. Green/white stripe in pin 2 and two blue/red stripe tied together in pin 1. Any idea what this is? I found something that may have indicated it’s possibly AC related; that would be ideal since I’ve done an AC delete and if it doesn’t have a home then it’s fine.
Next, ABA has this connecter, grey/yellow stripe pin 3, green/white stripe pin 2, solid yellow and blue/red stripe pin 1. Any idea of its function?
Then, in kind of a bizarre one- the ABA engine harness has a six prong red female. The closest equivalent connector in the VR6 harness is a 4 pin yellow female. They have similar wires in similar places, specifically black/green stripe in pin 1, black yellow stripe in pin 2, brown/red stripe in pin 3 and black/white stripe in pin 4. The two extra wires on the ABA connector are violet/black stripe in pin 5 and brown/yellow stripe in pin 6 and they loop back to I believe connecter G2 at relay panel. I traced the wires on the ABA loom and the brown/red stripe and a ground goes to the hood-ajar microswitch at the hood latch. I guess… what should I do? Splice pins 1-4 from VR6 female on harness to its 4 pin male counterpart in the dash? Then what to do with the orphaned pin 5/6? Any insight on this one would be majorly appreciated. Here’s the connectors I’m referring to:
Then, VR6 has two pin solid red, red/black stripe. No equivalent on ABA harness. Thicker gauge. I think this might be for alarm, can anyone confirm? I think there was a design difference between alarm systems iirc.
Lastly, the ABA has this two pin blue connector with no equivalent on the VR6 harness. Any idea of its functionality?
A couple of parting thoughts- I’m hoping some of these things are borderline non-issues. This is kinda a track-style build; I’ve done a PS/AC/SAI/PCV/EVAP/cruise control and washer fluid delete. Meaning a lotta electrical left unplugged and simplified. I’ll take any suggestions you guys have or any recommendations for anywhere else to do my own research further. Feel absolutely free to PM me, and if anyone’s in middle Tennessee maybe stop on by the garage!
