1 - 5 of 5 Posts
just driving around today and noticed that my front end moves up and down pretty frastically when i give it some torque. it only does it when i put a load on it from a cruize. it seems like the same thing as when i snapped my subframe which was replaced about six months ago. i am going out to make sure the subframe bolts are still tight but just checking if anyone had any idea of what else it could be. tia
Re: help if you can!!!! (sensory overload)
Sounds like maybe motor mounts?
Open the hood and have a friend ease off the clutch into first gear w/ the Ebrake on. If it is the mounts the motor will move ALOT in the bay.
Re: help if you can!!!! (Krautaholic)
Put your car up on jackstands and "wobble the tires back and forth" could be your A arm bushings
Re: help if you can!!!! (GKONYA)
yeah i just launched the front of the motor about 6 inches upward. guess i gotta get some turn 2 mounts. anyone know where the discounted or local seller Turn 2 mounts are at?
1 - 5 of 5 Posts
