Really helpful, man. Thank you. I have a ZF 5 speed, shifter linkage, pedal assembly and 2 driveshafts among other small items in preparation for the manual swap. It's a must and I know it'll wake up the car. I want to do this swap THIS year so that I can get it done and then worry about sub-frame reinforcement a bit later.Awesome awesome awesome. So now when you're not sure if you want to do something, ask yourself if it helps you get to that vision.
- An MT swap? Definitely, the car you described is either MT or dual clutch.
- Steering rack? I'd say so. @Sold Over Sticker can tell you all about power steering fade in golden era BMWs, let alone any ratio benefits.
- Wide body? Probably not. While awesome, it'd be expensive to do, and expensive to fix if you rub a wall. Not to mention wheel bearings on a track car are already stressed.
I also have a ZHP steering rack waiting as well. I did my standard few hours of research last night and found that at this point (and really throughout history) there aren't any tasteful and/or subtle kits for an E46. I may just try to source some nice ZHP/Mtech parts.
I was thinking about this kind of stuff too. Rear seat delete but not just leaving it bare. Cover it with a bit of insulation to make it livable (I'm thinking mostly around the parcel shelf and pass-through area). The 3pt harness stuff is very enlightening.Etc. etc. That's a vision I've thought about quite a lot, and really, not far off from how I'm building the Daytona. FWIW, in an E46, personally I'd probably be looking at pulling the carpets and back seat but not the dash, center console, or tops of the door cards, as stiff a suspension as I could reasonably stand, basic bolt-on power stuff like cat back and intake, a half-cage/roll hoop, bucket seats (leaving the 3-pt belts but also having harnesses). Going for coffee? 3-pt; I can still check blind spots, reach stuff in the car, and don't need to wear a HANS/helmet. At the track with a HANS? 4-, 5-, or 6-pt. And then Stoptech brakes with the widest wheels that will clear wrapped in a barely legal tire. YMMV on all that--maybe by a lot--but my point is just to keep those decisions in context. 🍺
I do have to think about new seats, manually adjustable but something livable and comfortable.
These are ALSO great points. IDK if I'd even be ready to get a trailer by the time our planned lease of the CX-50 was still in place. I'm know I'm getting ahead of myself, but I'm also trying to think a few steps ahead. I know tires will be my biggest expense at some point too.Having a dedicated daily is going to open up your options sooo much. CX-50 is a great car, but 3500lb tow rating is going to be tough for towing an E46. You'd need the lightest aluminum trailer you could get ($$$) and the E46 would have to be pretty well stripped. If towing this car is something you intend to do, I'd strongly recommend looking at bigger stuff, at least 4,500lbs for an open trailer and 6,500lbs for enclosed. It'll cost a little more upfront, and won't be as fun to drive, but it won't cost as much as if you realize you went too small the first time you tow. I doubt you want a truck; on that thought JGC is a good example of something I'd recommend.
