1 - 4 of 4 Posts
Girlfriend.She drives a 2001 Jetta and her radio stopped working.I cheked the fuse box but none of the icons next to the fuses resembled a radio.Her appt. at the dealer is friday and she misses her tunes.Could you guys help a fellow dubber out so I can earn some points with my G.F. Not that I need them or anything.
TIA
Re: Help me look good for my... (Yourapeein86)
if the security light still blinks on the radio, all you have to do is pull the fuse turn the key on for 15 seconds, then turn it off, put the fuse back in turn the key on, and then it should work.
this happened in my buddies gti.
I forget which fuse it is though, i think its 15 or somethin. ill check my bentley and get back too you.
Keep in mind this will only a cure if your security light still blinks.
Re: Help me look good for my... (anderskt)
Fuse identities for A4.....
-----------------[ S8 ][S 12][S 16][S 20]
-----------[ S5 ][ S9 ][S 13][S 17][S 21]
[ S1 ][ S3 ][ S6 ][S 10][S 14][S 18][S 22]
[ S2 ][ S4 ][ S7 ][S 11][S 15][S 19][S 23]
[ S 24 ] [ S 31 ] [ S 38 ] -- -- --
[ S 25 ] [ S 32 ] [ S 39 ] R R R
[ S 26 ] [ S 33 ] [ S 40 ] S S S
[ S 27 ] [ S 34 ] [ S 41 ] -- -- --
[ S 28 ] [ S 35 ] [ S 42 ] R R
[ S 29 ] [ S 36 ] [ S 43 ] S S
[ S 30 ] [ S 37 ] [ S 44 ] -- --
S1=10 AMP=Heated washer nozzles, glove compartment light, memory seat...
S2=10 AMP=Turn Signal System
S3=5 AMP=Fog Light Relay, Instrument Panel Dimmer Switch
S4=5 AMP=License Plate Lamps
S5=7.5 AMP=Comfort System, Cruise Control, Climatronic, A/C, Heated Seat Control Modules, Day/Night Dimming Mirror, Control Module and Control Unit for Multifunction Steering Wheel.
S6=5 AMP=Central Locking System
S7=10 AMP=Back-up Lights, Speedometer Vehicle Speed Sensor.
S8=OPEN
S9=5 AMP=Anti-Lock Brakes.
S10=10 AMP for GAS/5 AMPS for Diesel=ECM
S11=5 AMP=Instrument Cluster
S12=7.5 AMP=B+ (battery positive for data-link connector) (DLC).
S13=10 AMP=Brake Lights
S14=10 AMP=Interior Lights, Central Locking System
S15=5 AMP=Instrument Cluster, Automatic Transmission Control Module (TCM).
S16=10 AMP=A/C Clutch, After Run Coolant Pump.
S17=Open
S18=10 AMP=High Beam Right
S19=10 AMP=High Beam Left
S20=15 AMP=Low Beam Right
S21=15 AMP=Low Beam Left
S22=5 AMP=Parking and Side Marker Lights, Right
S23=5 AMP=Parking and Side Marker Lights, Left
S24=20 AMP=Front Wiper Motor, Washer Pump
S25=25 AMP=Fresh Air Blower, Climatronic, A/C
S26=25 AMP=Rear Window Defogger
S27=15 AMP=Rear Wiper Motor
S28=15 AMP=Fuel Pump, Gas Engine Only
S29=15 AMP Gas/10 AMPS Diesel=ECM
S30=20 AMP=Sunroof Control Module
S31=20 AMP=Automatic Transmission Control Module
S32=10 AMP Gas for Fuel Injectors/15 AMP Diesel for ECM
S33=20 AMP=Headlight Washer System
S34=10 AMP=Engine Control Elements
S35=30 AMP=12 VDC Outlet in Trunk
S36=15 AMP=Fog Lights
S37=10 AMP=Radio Terminal 86S, Instrument Cluster
S38=15 AMP=Central Locking System (w/ Power Windows), Luggage Compartment Light, Remote Fuel Tank Door, Rear Lid Unlock.
S39=15 AMP=Emergency Flashers
S40=20 AMP=Dual Tone Horn
S41=15 AMP=Cigarette Lighter
S42=25 AMP=Radio System
S43=10 AMP=Engine Control Elements
S44=15 AMP=Heated Seats
Hope this helps.
Fuse 42, and the 10A fuse on the back of the HU. YOu'll need radio removal keys to get hte HU out.
1 - 4 of 4 Posts
