1 - 4 of 4 Posts
Hello everyone!
For a few months I have noticed that the active suspension system is not working well for my CC. I notice that it sways a lot in curves and today by chance I think I found the problem...
Checking "Adaptation" in 44-Steering Assist I verify that in the "DCC" section I have an error
Computer Gadget Output device Font Automotive lighting
Does anyone know anything about this?
It doesn't leave an error in any channel, so I can't just delete it.
The shock absorbers are new, I changed them thinking they were worn out, but now I see that the problem is something else... The basic adjustment was also made and all the sensors give correct values.
Thank you!
Discussion Starter · #4 ·
Saturday,14,May,2022,14:26:36:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 15.7.0.2
Data version: 20150729
www.Ross-Tech.com
Dealer/Shop Name: 1234
VIN: WVWZZZ3CZBE726548 License Plate:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 25 37 42 44 46 4F 52 53 55
56 62 72
VIN: WVWZZZ3CZBE726548 Mileage: 138950km-86339miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
Part No SW: 06J 906 026 FA HW: 06J 907 309
Component: MED17.5 5843
Revision: AAH18--- Serial number: VWZCZ000000000
Coding: 0404000C1C070160
Shop #: WSC 12345 123 12345
VCID: 6ECFD9F3E097F072FD2C68D-803A
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 053 M HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2202
Revision: 05151112 Serial number: 00001008260470
Coding: 0000020
Shop #: WSC 05311 000 00000
VCID: 1F51F43757BD29FA065A8D1-804A
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --026--- Serial number: 00000706238318
Coding: 0002419
VCID: 62D7BDC3244F441269B4ECD-8036
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_Climatronic A01006
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 7EEFE9B3B0F78C726D8CB8D-802A
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 S HW: 3C8 937 049 S
Component: Bordnetz-SG H53 3101
Revision: 00H53000 Serial number: 00000004191934
Coding: F766CF8910463C004FA88F0028000000800BBF4F5A40094D174000000000
VCID: 4195524F81893F0A50EE1B9-8014
Subsystem 1 - Part No: 3C8 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 300810 010 0603
Coding: 00046997
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 220910 054 0403
Coding: 00209901
Shop #: WSC 12345
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 3C8 919 475 A HW: 3C8 919 475
Component: PARKHILFE 8K H07 0009
Revision: -------- Serial number: 08791026072442
Coding: 300101
VCID: 32770D83342F9892D994FCD-8066
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0070
Revision: 00000000 Serial number: 28091000360001
Coding: 010180
Shop #: WSC 05314 000 00000
VCID: 2741ECD70FEDED3A7EEA651-8072
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__301 VW10 HI 1918
Revision: 22014000 Serial number: 003K0PJXR0WU
Coding: 0012337
VCID: 4C8B737BB6CBE262B398925-8018
Subsystem 1 - Serial number: 6332MTS621562460
Subsystem 2 - Serial number: 6342MTS670162370
Subsystem 3 - Serial number: 6351HTS6LU2PE9KR
Subsystem 4 - Serial number: 6361HTS65TLGE9KJ
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C5 953 501 BG HW: 5K0 953 569 T
Component: LENKS.MODUL 009 0136
Revision: FF010038 Serial number: 20100923300790
Coding: 099A270002
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 6BC9D0E7D38509DADA52491-803E
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 830000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C8 920 880 SX HW: 3C8 920 880 SX
Component: KOMBI H03 0705
Coding: 140B00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04727
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 143BAB1BAE7B7622ABA80A5-8040
1 Fault Found:
10485825 - Internal Control Module Memory Check Sum Error
B2000 41 [137] - General checksum failure
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 N HW: 3C0 907 951
Component: J533 Gateway H14 0172
Revision: H14 Serial number: 1021G10917023B
Coding: FDA97F06400203001002
Shop #: WSC 08004 572 83243
VCID: 2C4B13FB160BC26293D8325-8078
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR
Component: IMMO 043 0383
Revision: 00043000 Serial number: VWZCZ000000000
Shop #: WSC 01574 002 1048576
VCID: 7AE7E5A3ACDFACD251A494D-802E
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H42 5238
Revision: AB001001 Serial number: VWZ6Z7K9267045
Coding: 00000400040000A2000F
VCID: 37613C97DF4D7DBAEE4AB51-8062
Subsystem 1 - Part No: 1T0 051 859 AS
Component: EU West V17 8557
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 1T0 959 701 AG HW: 3C0 959 793 A
Component: TUER-SG FT 002 0307
Revision: 12101005 Serial number: 0001548094
Coding: 0010F7
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 7CEBE3BBA6EB9E6243B8825-8028
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 703 C HW: 3C0 959 795 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0401
Serial number: 00000001670310
Coding: 0000D8
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
Component: J500__APA-BS KL.298 0802
Revision: 1AH03729 Serial number: 00102570356701
Coding: 0000258
VCID: 3B6920A7E36555DA0A32591-806E
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 043 0612
Coding: 18910A000186CE763601050520084F00005901
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 3C0 907 951
Component: EZE_2 H14 0172
Revision: -------- Serial number: 1021G10917023B
Coding: 01030100
VCID: 66DFA1D3C8673432859CB0D-8032
Subsystem 1 - Part No SW: 6R0 959 591 HW: 6R0 959 591
Component: J245/J878 H04 0054
Coding: 000006
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 1T0 959 702 AC HW: 3C0 959 792 A
Component: TUER-SG BT 002 0307
Revision: 14101005 Serial number: 0001551217
Coding: 0010F6
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 79E5FAAFA9D9AB4A58DEE39-802C
Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 704 C HW: 3C0 959 794 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0401
Serial number: 00000001669199
Coding: 0000D8
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
Component: J540 EPB3 VW-15417 0007
Revision: 011 Serial number: 00000000403014
Coding: 0000057
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 3493064
VCID: 347B0B9BCE3B9AA2CB68EA5-8060
Subsystem 1 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0003
Coding: 00000053
Subsystem 2 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0003
Coding: 00000053
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
End-------------------------(Elapsed Time: 03:02)--------------------------
The only error that appears is the instrument panel, which was changed by 3D.
1 - 4 of 4 Posts
