1 - 16 of 16 Posts
while im driving my headlights, fog lights, wipers and blower motor will all turn OFF!! at the same time! whats wrong with my car im about to sell it cause of this!
pic just for stopping by
Likely you have a relay or two that is loose. Look under the dash on the drivers side... There is a bunch of boxy things (relays) plugged into a unit that you can remove if you look carefully. Take this unit out and one by one remove each relay and push it back into the socket it came from. Once your done going through the relays, reinstall the unit and try your car out.
1 - 16 of 16 Posts
