1 - 8 of 8 Posts
Hey guys, I've got a problem.... my rocco bogs down in 2nd and 3rd gear when I turn higher rpms it sounds like it wants to stall.....
I've got spark, so thats not the problem, and I've:
-Changed the fuel pump relay
-Installed new fuel lines
-Cleaned out the air flow sensor plate
-Checked the Air/Fuel mixture
Now where would I go???
I don't have an O2 sensor because I have headers... but it never caused a problem b4... any help would be appreciated
Thanks,
Jesse
Re: Help, my 84 rocco is losing power in 3rd! (Scirocco_Clan_Man)
ok first things first
does your car have a full size spare tire ?
if it does not you have 2 fuel pumps and your intank pump is going to die on you or your screen on the intank pump is plugged i had the same thing happen to me so i changed the out fuel pump no tknowing i had 2 pumps i was young lol
let me know im sure we can get it worked out http://****************.com/smile/emthup.gif
Re: Help, my 84 rocco is losing power in 3rd! (wolf rocco)
the car has the smaller spare... its not a fullsize.. I changed the fuel pump and the other thing that was right beside it... I had no clue what it was other than it had fuel lines coming from it. I had a spare fuel pump off of an 86 that worked great with the other piece, so I just changed them both.
My next guess is its either the lack of an O2 Sensor or the fuel filter may be clogged...
Discussion Starter · #6 ·
Hey guys, thanks for the trouble shooting... I needed the help.. To conclude this, it was the intank fuel pump, there was no filter on it, so it sucked up all the crap in my tank and clogged the pump... I replaced the pump and got the filter and it runs better than ever. Anyway, since I've got new-found power, I'm gonna go spank some honda's
Thanks guys, you rule!
Jesse
1 - 8 of 8 Posts
