1 - 6 of 6 Posts
Re: help my spark plugs are white (Volks Folks)
check your dpr current... the reading should fluctuate between 3-5mA. The process is explained in the bently. You use a 3mm alan key to adjust it. http://****************.com/smile/emthup.gif Good Luck!
Check your compression.. white usually means coolant.. you may have a headgasket gone bad.. is the coolant level dropping or spurting out the vent of the over flow when the engine is running..
1 - 6 of 6 Posts
