1 - 4 of 4 Posts
Hi there guys!!! I want to change the hydraulic lifters in my 1992 1.8 8v GTI and I dont know where to start. I've looked in the archives but that doesnt help much. What else can I change whilst I'm changing the lifters?? (I dont mean a complete overhaul!!) just some cheap other stuff that I can change. I want to do it this weekend. I've got the HAYNES from '84 - '87 but mine is '92. Thanx in advance
Re: HELP!!!! new lifters (1992jetta-2)
I thought it was click click click for you, T-bird.
You can change the timing belt, cam, and cam oil seal. It is easier to do the injector o-rings when you have the valve cover off as well. Other than that, you'll need a valve spring compressor, air pressure regulator and adaptor to hold the valves in place if you wanted to change the valve stem seals.
Re: HELP!!!! new lifters (Patrick Schmidt)
quote:[HR][/HR]You can change the timing belt, cam, and cam oil seal. It is easier to do the injector o-rings when you have the valve cover off as well. Other than that, you'll need a valve spring compressor, air pressure regulator and adaptor to hold the valves in place if you wanted to change the valve stem seals.[HR][/HR]​
I did all of the above on my car at 175k..started out as a t-belt replacement, then I realized how cheap the lifters and valve stem seals were, and so we did them along with a new cam. Car uses *zero* oil since and compression/leakdown #'s are near factory spec now.
It's very easy to drop a valve into the cylinder if you don't have it TDC, but with the right tool and cranking the engine carefully you can get it back without pulling the head. (Of course it's easier to just not drop it into the cylinder in the first place
One word of caution--make sure you get OEM German valve seals. I had to do the job *twice* in 2 days because the first set I got weren't OEM (I guess) and within 20 miles the car was smoking like crazy--4 of 8 didn't seat at all.
1 - 4 of 4 Posts
