1 - 6 of 6 Posts
Huge oil leak, some was coming from the oil filter. People didn’t put the gasket on the last oil change. Still leaking all over the place, and I can’t seem to pinpoint it since everything is soaked in oil. 2015 golf 1.8t
Check your levels regularly and could just be residual migration if your level stays good. How low did it get?
Check your levels regularly and was it. will be just be residual migration if your level stays good. How low did it get?
I thought it may be residual but after doing my oil change (about a month ago) the oil still is going down. Roughly a quart every 3-4 weeks. I’ll add up dye to the oil tomorrow and see if I can find it with a light.
Maybe take a look at my thread here. Was the o-ring replaced under warranty....
1 - 6 of 6 Posts
