HELP!!!! Oil Plug is striped what can I do!!!!!!!
597 Views 15 Replies 10 Participants Last post by  aburchell44
HELP!!!! Oil Plug is striped what can I do!!!!!!! My car is leaking oil, and realized it leaking oil, cause the pluged it striped. What are some options I can do to fix it???
1 - 16 of 16 Posts
3
Re: HELP!!!! Oil Plug is striped what can I do!!!!!!! (96jettabink)
Buy a new oil pan, oil pan gasket, and a drain plug
See less See more
2
1. Uhm, buy a new plug
2. Who was the gorilla that torqued it down so hard in the first place?!?
With the crush washer in place it doesn't take much to lock it down.
See less See more
Re: HELP!!!! Oil Plug is striped what can I do!!!!!!! (SoLo2pointO)
Where is the best place to get a oil pan, plug, and gasket http://****************.com/smile/emthup.gif
[Modified by 96jettabink, 3:47 PM 2-11-2002]
See less See more
vwparts.com
Re: HELP!!!! Oil Plug is striped what can I do!!!!!!! (JetTAFLiTe)
Is it the bolt or the hole that is stripped?
WOHA DONT BUY A NEW PAN!!!! Go to napa and buy an oversized oil pan plug. Its like 4 dollars from a parts store. It makes Its own threads when it goes in. DONT BUY A NEW PAN YIKES!!! OVERSIZED PLUG get it
2
Re: HELP!!!! Oil Plug is striped what can I do!!!!!!! (jayseal22)
what do u mean over sized? is it gonna fit on the car? http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
[Modified by 96jettabink, 4:34 PM 2-11-2002]
See less See more
2
what do u mean oversized oil pan, will it fit over stock http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
See less See more
he said "oversized oil pan PLUG"!!
See less See more
no no you pull the old PLUG(i dont get the joke?) and then just screw this one in. It is larger and makes its own treads. ANd then your done
quote:[HR][/HR]no no you pull the old PLUG(i dont get the joke?) and then just screw this one in. It is larger and makes its own treads. ANd then your done [HR][/HR]​
wouldnt that cause metal shavings to get inside the oil pan??? that cant be good.
After installing the new plug remove it and re-drain oil. That should fluch out any shavings.
Re: HELP!!!! Oil Plug is striped what can I do!!!!!!! (Fast16v)
To eliminate the metal shavings try to find a oversized manatized drain plug that would solve all the problums
Re: HELP!!!! Oil Plug is striped what can I do!!!!!!! (GTI2.0)
quote:[HR][/HR]To eliminate the metal shavings try to find a oversized manatized drain plug that would solve all the problums[HR][/HR]​
See less See more
Re: HELP!!!! Oil Plug is striped what can I do!!!!!!! (Y2KRICEBOY)
Heli Coil
1 - 16 of 16 Posts
