Re: Help - Remove cd player for VAG (NJTDI)
the sony dewck should have a trim ring around it. pull that off (be firm yet gentle) and on each side of the deck there will be 2 little tabs, push those in and pull out. the deck should slide out. after that remote the wiring converter harness and pop the factory back in and make sure u have/get a set of factory removal keys so you can put the sony back in.
