1 - 1 of 1 Posts
My clutch doesn't fully disengage until the pedal is pushed all the way to the floor- and then just barely. Car shifts fine while moving and holds power with no slip. I believe it my clutch slave cylinder.
Is there a procedure to bleed it or a test to check it?
Other Causes? Throw-out bearing or pressure plate?
Thanks.
1 - 1 of 1 Posts
