1 - 5 of 5 Posts
Can some one please help me i'm try to put a front kit on and the stock bumper cover is being a *****.Any advice would help.Thanks
Re: Help With Corrado Front Bumper Cover (limecorrado)
remove the bumper with the rebar still attached to it. it has four bolts that go into the subframe(17mm) then it will be easier to get to the plastic tabs holding the bumper cover on.
Don't forget to disconnect all the electrical harnesses from the bumper before you take it all the way off. You don't want to end up with all the weight of the bumper hanging by a couple of wires like I did
1 - 5 of 5 Posts
