Sorry if I missed it in the search, but here is my problem
2001 Jetta GLS 1.8t Wolf AWW
Symptoms-
CEL - On
EPC - Comes on after idling for a while, the engine will drop revs or die and then the light will come on. After sitting for a few hours it will go off.
While driving it seems to be lacking in power and sometimes surges.
Replaced pre cat o2 sensor with a minor change for about 20 miles and then the same symptoms came back.
I am guessing at this point that it may be MAF but not positive.
Codes:
P0171 System too Lean (Bank 1)
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected \______Sometimes other cylinders.
P0302 Cylinder 2 Misfire Detected /
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
Any and all help would be appreciated. If I missed it in the searches, sorry.
Symptoms-
CEL - On
Codes:
