1 - 8 of 8 Posts
trying to make my own rear sway bar. i have access to everything needed to make them but just need the dimensions.
anyone know the dimensions for a shine swaybar or if someone did a replica of it, please post the measurements... thanks.
Re: help with rear sway bar (crazykidbig58)
id most likely make it out of 1" DOM tubing. which is close to a 28mm swaybar that someone would buy from a store.
why would i make it? well to buy the material it only will cost about $15 and im in a chassis fabrication classand it will look like the shine once its complete. but i just need the measurements or someone with a mk3 so i can measure it out.
Re: help with rear sway bar (drmerdp)
well u can get some serious tubing......umm u could buy a good quality steel, with like 60 or 80 wall......thatd be pretty nuts......it is much more fun to build ur own stuff.....currently trying to do a carbon fiber interior.....thanks to vwoah hahaha, got me hooked
Discussion Starter · #7 ·
well i since i have a mk2 i started making them first. basiclly the same concept just little difference in dimensions. im using 1"x.560" DOM. so far i got the sleeves for the bolts done and notched already tomorrow ill weld it together and probably get it powdercoated. its nice to be at a auto school that has everything right next to eachother and alot of people that can help u out. http://****************.com/smile/emthup.gif
as for the mk3 swaybar i gotta measure everything from my buddys gti, i hope to get atleast 1 mk3 done before next thurday(last day of class).
ill post some pics if i get the mk3 done if not ill put my mk2 up
Re: help with rear sway bar (VDuBJett92)
Quote, originally posted by VDuBJett92 »
It must be! http://****************.com/smile/emthup.gif
Sounds good! http://****************.com/smile/emthup.gif
1 - 8 of 8 Posts
