1 - 4 of 4 Posts
I got my tranny replaced and it had 90K on it. I took off my heatshield (big mistake) a while ago because it was rattling on my mid-pipe, but I put it back on today. I figured that the reason my shifter was sticky was because of the heat it was exposed to. To make a long story short, it's still acting up. Hard to shift into 2nd and 4th; should I get new bushings or short shift kit or what??
Discussion Starter · #2 ·
Re: Help with shifter (Neuspeed Gti)
Bump, need help with this, no use in selling the car if it's not working properly...
Bump
i'd check the alignment first using the VW tool or a similar ghetto-rigged item.
then i'd inspect all of the bushings - if you removed the heat shield you might have melted the bushings, particularly the shift rod bushing.
a short-shift kit isn't going to improve things, because i doubt it's the linkage in the engine bay. sounds like the problem is in the shift rod or shifter box above the exhaust...
1 - 4 of 4 Posts
