1 - 10 of 10 Posts
i have these two codes that came up when i hex com'd the car
18047- Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
16687- Cylinder 3 Misfire Detected
my questions are can i fix them myself and how? or do i have to go to the dealership to get them fixed.. let me know if you have any answers
Thanks
Re: help with vag com codes on how to fix (huevon)
Hmmm.. If I were at work I could drop you some suggestions out of Vesis..
First off.. what car are we working on?
Year
Model
Engine size?
Re: help with vag com codes on how to fix (Black Jetta)
I have a 2000 4dr Golf GLS 1.8t with an AWD engine
hey Heath. all of those codes that we pulled on my car that night i got figured out by searchin the 1.8t forum. i dont know if u did or not yet. but that is what i would suggest. worked out for me. let me know how it goes. thanks again for vagin my car that thing is sick
Re: help with vag com codes on how to fix (TurbinDub18)
how did you fix the misfires turbin?
i didnt fix them yet. i just did a little research and it sounds like the first step is to repleace the plugs. it was a common problem and some people said that there is somthing at the dealer that can fix it?
some of the threads were really long so i didnt read them all. i will when i get a chance sometime.
thanks again man for the reading
Only dealer fix that is in a recall for your car is the WG recall.
AKA coilpacks. If you have already had it done you need to look
elsewhere for the misfire. IE bad injector or sticky valves maybe even cheap gas. I know you all put 91 octane in your tank every time right?
Have you had all your services done?
What kind of mileage do you currently have?
Reason I ask is there are solutions for injectors and valve issues
that are pretty inexpensive.
OH.. and the throttle position sensor is most likely the throttle pedal. It has a potentiometer on it so it can tell how far down your lead foot has it.
and adjust fuel trim accordingly.
The wiring to the sensor may be bad or the sensor itself may need to be replaced. http://****************.com/smile/emthup.gif
Modified by Black Jetta at 4:54 AM 5-19-2004
Nothing to see here.. just storing info I need to help.
Quote, originally posted by huevon »
Address 01: Engine
Controller: 06A 906 032 CL
Component: 1.8l 5V 110kW TLG V004
Coding: 06500
Shop #: WSC 00000
3 Faults Found:
18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
P1639 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
17796 - Internal Control Module Malfunction
P1388 - 35-10 - - - Intermittent
Readiness: 0000 1000
i have replaced the pedal sensor and that stopped most of the surging
I have tested the wire and the ecu and check engine light went out but the
car has switched back and forth between the two modes ,limp and regular, at
the worst times.
Also, i had my vin ran at moutain states motors dealership and they said
that i didnt have any recalls with my maf, coil packs or plastic window
mounts..so if you have any other suggestions just let me know
PLus, i replaced the negative battery cable, the battery ( now i have an
Optima battery ), new NGK spark plugs rated a 7E for the chipped turbo...
This car is my daily driver and i can barely get up the hill to my day care
lady. today i had it in first gear with the pedal to the floor and i barely
got up the hill...what a pain in the butt..but i will see what happens
tomorrow with the acceleration..
btw Huevon:
Window regulators, MAF are not recalls.. they are warranty.
Odds are it is the MAF and some glitch with your Pedal Sensor.
I will talk to you via phone tomorrow.
Modified by Black Jetta at 6:38 AM 6-3-2004
Hey heath, I need to get with you some time so you can pull the codes off mine. Let me know when you're free...thanks man
Josh
Discussion Starter · #10 ·
Re: help with vag com codes on how to fix (vwgti303)
my new codes ..i fixed all but one of the old ones ( G79) is still here
2000 Golf GLS 1.8T with 67K mileage...chipped, Forge DV
> Address 01: Engine
> Coding: 06500
> Shop #: WSC 00000
> 3 Faults Found:
1 - 10 of 10 Posts
