1 - 2 of 2 Posts
92 8v digifant I
At first it would start run normal. Then after about 5min. At idle engine runs rough then dies. Any suggestions? Anything I should lookout for? I have replaced both fuel pumps, pressure regulator. IAC. Spark plugs, wires. Temp sensor, knock sensor & fuel pump relay. And now the car won’t start at all. Any help would be great. Thanks.edit; swapped maf and ecu from running cars and that still did nothing.
How about listing the tests you've done vs the amount of parts you replaced. Does it get 12V? How's the power supply, ignition, and grounds. Does the coil get a signal to spark? Do you have any diagnostic tools, knowledge, books?
1 - 2 of 2 Posts
