1 - 20 of 29 Posts
Any suggestions on tire size and adapter thickness.... 2 wheels are 16x8.5 et 56 and 2 are 16x9.5 Also anyone in need of a set of 245-50-16 tires let me know they are free for the taking!
Modified by AirWater98 at 5:43 PM 2-11-2004
Modified by AirWater98 at 8:09 PM 2-11-2004
Premium Member
get 20-25mm adapters
parts4vws.com has them
you will have to roll your fenders... alot.
as for tires...
I would look for 225/40/16s (may have to stretch them a little)
Discussion Starter · #9 ·
Re: (Ghetto-8v)
205 40's ehh... that's the hot setup? I wish i could find people with similar setups to see pics and such... i have gotten soo much conflicting input it is rediculous, but i do appreciate it!!!! Thanks
I was also looking at this
http://www.miata.net/garage/tirecalc.html the 215 40 16 is pretty damn close and the tire manufacturers say they are acceptable to put on a 8.5" wheel...
Modified by AirWater98 at 7:35 PM 2-11-2004
Re: (1SickWhtDub)
wow http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif nice wheels
Discussion Starter · #12 ·
Re: (VR6NH)
Quote, originally posted by VR6NH »
Any guesses how much I paid?
Re: (volks98jetta2.0)
Quote, originally posted by volks98jetta2.0 »
i hate you
you and thane should start polishing all the mesh. now that would look hot
FORK THAT! I ain't helping the bastard 1 bit. If you only knew how cheap he got them for...
I am spending most of my time plotting his demise...
****! Now everyone knows... MWUHAHAHAHAHAHAHAHAH
Re: (gti_driver5)
so ya 215s plus running an adapter means your gonna pull off the mexipack special look the tires are going to be sticking out beyond the fenders....
Re: (AirWater98)
Quote, originally posted by AirWater98 »
ill take a wild guess, ill say, 468 shipped....and im guessing 2 of them are 16x9.5's to......what do i win if im right?
Discussion Starter · #16 ·
Re: (germantoydeux)
Quote, originally posted by germantoydeux »
LOL so 205's then
Discussion Starter · #19 ·
Re: (germantoydeux)
I think Chapel is right.... adding adapters kicks the wheels out the other way which will bring them out towards the fender and reducing the offset.
Premium Member
uh, wrong way
adding an adapter will decrease offset.
the only way to ADD offset is to grind off backing material
If your ET is a +40
and you add a 20mm spacer
you SUBTRACT 20mm (+ET20)
if your ET is a +40 and you grind down 20mm of backing material you'll ADD 20mm (+ET60)
1 - 20 of 29 Posts
