Re: hesitates from 2k to 4-5k, poor gas mileage, etc. etc. (black92gti16v)
If this wasn't a problem before, the first thing I would check would be the valvle timing. Its pretty easy. Line up the mark on the crankshaft pulley with the mark on the lower timing belt cover (top of pulley). Then take off the top half of the timing belt cover and see if the mark on the camshaft pulley lines up. I bet you're a tooth or two off.
