1 - 13 of 13 Posts
Just curious what mode are you usually in? I tried sport normal and comfort. I think in sport mode the gears shift kinda weirdly, not sure if that is because I haven't fully broken in yet. Comfort mode the gears shift pretty lazily which I also dislike. Now my favorite is normal which IMO has the smoothest shifting.
Sport mode for me - but I have only had my Arteon for a couple of weeks. Interesting that you notice such a difference. I need to test Comfort and Normal modes, now.
Custom mode for me, the range of adjustments on the custom mode is one of the things that sold me on this car. I have the tranny and steering set to sport and suspension set to comfort. If I need more power, I put the shifter into sport mode and its a bit quicker on the throttle and if I need more corning stability, I put the car into sport mode.
Custom mode
Chassis: stiffest it can be
Steering: sport
Engine: normal
The engine is too revvy/likely to hang in higher RPMs unnecessarily in sport mode imo.
I’m always in custom with everything in sport and the firmest suspension. But I’ll change from firmest to softest dcc settings depending on the roads.
Custom virtually all the time:
Suspension: Between normal and comfort
Drive: Normal
Steering: Sport
Headlights: Sport
ACC: Normal
Climate control: Normal
I enjoy the heavier steering of Sport but don't want to be holding high gears all the time. Roads around here are bad enough that Sport suspension is not very fun for everyday commuting.
Drive: Normal
Steering: Sport
Headlights: Sport
ACC: Normal
Same here!
I'll go into Sport though on secondary highways with smooth pavement.
And Comfort for really rough stretches.
(Plus Econo a few times when I was really pushing the cruising range between fill-ups...)
Overall, yet another really nice feature of the Arteon, definitely not just a gimmick.
I also recently discovered (via this forum, after a mere 50,000+ miles!) that the drive can easily be put into Sport independent of the overall mode selection.
Discussion Starter · #10 ·
It may be just me. I can't really tell the difference in suspension in different modes... so what I care is just gear shifting, and normal mode does it best for me.
Mainly normal on the day to day, comfort of the roads are bad (Atlanta), and sport of I’m in the mountains. Eco if road tripping.
Custom for me - all settings to sport except suspension dialed back 2-3 clicks from max. I've always found the best handling isn't always the maximum stiffness - just a little bit of give can tame mid-corner bumps and cracks while still keeping body roll at a minimum. On a track, max stiff might be great, but on less than perfect roads, I like to keep it sporty but with just a little more travel to handle the imperfections better.
Sport mode mostly, sometimes normal mode but only if I'm careful because of the tendency to bottom out.
1 - 13 of 13 Posts
