1 - 20 of 49 Posts
Hi, I have a Golf GTi IV 2001 model.
Can you guys give me some tech about the car?
Does it have a super or a turbo charger.
How much is the turbone blowing in Psi?
Im a starting to modify the engine.
I will be getting a Filter, Bigger turbine intake, 60mm downpipe and cat back exhaust.
All from neuspeed.
That should put it up to 200 hp. Stock 150.
How does that sound?
Re: Hi, Im new. starting to modify (Maggi)
Quote, originally posted by Maggi »
All from neuspeed.
Wow
All from neuspeed.
Welcome, Start by reading the FAQ.
Turbo charged
Neuspeed catback/downpipe = NO
Neuspeed intake = maybe
Push your car up to 200hp from 150 hp with just those? You wish.
Discussion Starter · #7 ·
Re: Hi, Im new. starting to modify (White_Turbo)
I forgot to mention, i will also get a Bigger better flowing intercooler pipe.
A car with only those mods, but also a chip was dyno mesured 224 hp and 179 whp!
This equates to a 35% increase in peak road horsepower and a 50% increase in peak road torque.
If yoy dont belive that, Read this.
http://www.europeancarweb.com/...speed/
All from neuspeed.
UMMM, no it will not get you 200 hp. your forgeting an ECU chip. BIG factor in there "claimed" 225 HP. actual Hp for a net of 179 is around 205 crank. with the parts you stated, you will probably GROSS 175-180 HP or so.
Re: (Vapormike)
Dude, you might want to read up on the car a little before you jump into modding head first. Also do some research before you buy anything. Neuspeed doesn't necessaryily make the best products. Once you know what you want to buy, you should check out the classifieds and look for group buys and save a buck or two.
Even after reading that I still don't believe what you believe, because you did not say you will get a chip. With just the things you listed, it will not get you to 200hp.....
Re: Hi, Im new. starting to modify (KnightOwl)
this is EXACTLY why I come to this forum...for the laughs
Discussion Starter · #20 ·
Ok, thx guys.
No need to make fun of me here! Is this the way you treat new people on the forum?
I have been told that i would get up to 200 hp with thoose mods. Maybe its only 180-190 then.
1 - 20 of 49 Posts
